New to the forum. 4.3L to 350 in 85 Monte
CSCMONTE
n00b
Feb 27, 2007
2
Hello All,
I have an 85 monte with a 4.3z engine and want to swap it out with a 350 chevy SB. I saw lots of posts on here about 3.8 to 350 but, none on the 4.3 to 350. any help at all is appreciated.
TIA
RedHotRegal
266
Ontario, Canada
Yours should be really simple. I beleive the 4.3 is a 350 basically with the rear cylinders taken off to make it a v6. If so then the mounts etc... should all be the same.
jerrycad472
264
16
Detroit, MI
Yours will be much simpler than swaping from an 3.8 Buick to a SBC.
1) You can reuse all of your engine accessories, Alternator, Pulley's, starter etc.
2) Make sure you use the right harmonic balancer for your engine choice, probably not safe to assume the V6 one is correct.
3) You can use the same transmission.
4) You will have to replace the Engine mount brackets that bolt to the frame with ones from a V8 car, as the V6 style hang back off the Cross Member. (At least that is how my Chevy 3.8 (229) was.) I think the engine mount that bolts to the block can be reused.
BB Olds
Feb 18, 2007
83
Wi.
the 4.3 frame mounts can be re used but you will need to move them forward the holes are there in the frame .
jerrycad472
264
16
Detroit, MI
I can't say that I have seen the 4.3 Mounts but the 229 were definately different than the V8 ones. Distinctively different shape in order to extend rearward from the cross memeber. But it is possible that they could be repositioned to work with the V8. Give it a try before you spend the money to buy new ones.
beachbum29
10
Upstate
the 4.3 mounts will work, I believe you've gotta move them one spot forward, but to be honest, at 8 bucks apeace, i'd go new
