HELP New trunk strut lift supports
Swindells
Swindells
21
I got an 81 cut supreme
I just had to hunt down and find 2 new struts to hold my trunk up (which was not an easy task) as I was sick up propping it with a stick
Upon installing the new struts
My trunk still falls fairly easily
Now I don’t know if I missed a step?
Or if the new struts are just old and no good themselves
Or am I just being too picky cause it will stay up
But a slight touch or shake of the car will cause it to fall down
Anyone else encountered this problem?
melloelky
melloelky
1,302
mass
it should stay up more than that.were they direct replacements or did i you spec them out yourself?
Swindells
Swindells
21
I had lordco and Canadian tire hunt them down
Both looked up my vehicle and said these were the ones
Overall I ended up getting both through Canadian tire from separate locations but same part number
Brand new
But they barely support the trunk weight
85442/86buick
85442/86buick
521
Toronto
when you search Rockauto ,what's the part number ?
And yes there are parts on my car from Lordco....main & 3 rd ? in Vancouver they rock
PS - men will hunt down car parts on vacation.........sorry ladies
Swindells
Swindells
21
Depends the company make
But it’s 4100 Or 901301
From what I’ve seen
Which is exactly what I’ve got
The image is the part on amazon and lists the matching part numbers
I just feel maybe the ones I got were already defective from sitting for years
85442/86buick
85442/86buick
521
Toronto
Old stock , good point
Reactions: fleming442
N
NCTyphoonKid
205
I ordered a set on rock auto for my regal and they hold the weight of the trunk lid plus some
Swindells
Swindells
21
They
They only have 1 in stock at rockauto
The struggle continues
How often does rockauto restock?
Ribbedroof
Ribbedroof
2,854
Wellston, OK
Looks like 1 regular Monroe and 1 Max lift Monroe. However, they have Sachs, which are IMO the best supports available in the aftermarket. Have a set of Sachs on daughters XJ Cherokee for 3 years, still good..and the gates are pretty heavy
Also available at O'Reilly stores if you have them near you for only a couple bucks more.
