New to the forum this was a father son project unfortunately he has a progressive incurable disease so I have taken over with him to consult and live vicariously through me. Part choices and purchases were done by him though please refrain from any truly negative comments other than feedback by time we had money for the project he had been out of engine building etc from the disease for 25 years and unfortunately the disease effects his memory somewhat.
Extreme budget build and will be used by me as a fun daily I am very familiar with mechanical work though mainly did all my work on obd 2 vehicles and am learning as I go especially through the forums. I have never actually built an engine but have done plenty of tear downs to short block for internal work.
I will ask a bunch of stupid questions from ignorance and have terrible punctuation and grammar heads up. Trying to go back and fix any accidental mistakes or bad choices he made without telling him so I appreciate all your help
1983 olds cutlass Calais originally 3.8l with 1968 sbo 350 bored .30 over
#5 heads I believe
Completely unknown pistons 😐
Guessed to be Keith black cast unfortunately
Summit mv8600 600cfm carb
RV cam completely unknown specs 😑
Edelbrock 7111 intake currently sealed with Mondello gaskets with Mondello heat riser block off plates and super ugly RTV black because I somehow screwed up the install and couldn’t afford to redo it
Bolt in valley pan or windage tray not sure what it’s called.
W30 retro exhaust manifolds I believe
MSD ready to run distributor blaster 3 coil
AC Delco plugs gapped .34 I believe
Newer 3 core radiator I think
Will be getting rotella t6 full synthetic 5w40
Wix filter 51258 hopefully I bough the right one.
Milodon I think deep oil pan apparently has a oil capacity of 8 quarts?
TCI TH350 street rodder package
TCI 1700rpm stall non lockup converter
TCI trans cooler
TCI max shift trans fluid
Stock 7.5 rear end and drive shaft no idea of ratio and too lazy to check tag.
All new moog front suspension including coils
New rear coils shocks and I believe other items I’m unsure of
1 year old lower steering shaft
Stainless steel brand performance front disc brakes I think
plans:
Either strengthen and change gears in 7.5 if it and the driveshaft will survive or do 8.5
Will eventually paint it and work on interior
Will like never have slicks
Purely for street and daily fun driving and if I’m lucky acceptable mpg
Pictures on the way
#5 heads I believe
TCI trans cooler
plans:
Pictures on the way
