New user 84Cutty
Jae_84
5
New user. Bought 84 cutlass for my first car in 2k11 and have been working in it since. Replaced knocking 350 with an 010 350, don't know where it actually came from originally so a guesstimate and fitting has helped me through. It has been sitting intermittently since then and forced me to upgrade but won't give up on my baby. Dealing with starter issues now though, any help is surely appreciated.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,807
Louisville, KY
Welcome aboard from KY. What type of starter issues are you having? You've come to the right place....tons of cool rides and knowledgeable guys willing to help!
Also, let's see some pics of the cutlass!
LukeZ
537
323
Delaware
Welcome from Delaware! Post pics!
Jae_84
5
Had flexplate replaced a year ago along with bulky starter and have been missing and shimming since
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,807
Louisville, KY
1st thing to ensure the flexplate tooth count matches that of the starter, and shimmed correctly so the starter gear disengages properly.
If the engine is missing, it shouldn't be starter related unless you have a short in the wiring from the fusebox to the starter lug~alternator post???? If you haven't already done it, start testing different circuits with a multimeter....a loose ground can wreak havoc and cause a migraine!
Jae_84
5
IMAG0300.jpg wired in third brake light
edelbrock carb
replaced semi bench seat with buckets I found salvaging parts IMAG0299.jpg headliner was my first salvage grab
Landau top had been removed I removed the moulding and studs
replaced original cluster with rally style guages
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,807
Louisville, KY
Almost sounds like the flexplate is the wrong size diameter-wise. If the starter gear is missing the teeth on the flexplate that's what i would look at. There is probably something I'm missing, others should chime in.
