1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
FOR SALE NJ- 1983 Monte Carlo SS LSX SWAPPED / built trans
Discussion in 'Cars for Sale / Trade' started by 6spdg37s, Sep 11, 2017.
  1. 6spdg37s
    6spdg37s Master Mechanic
    Oct 21, 2016
    372
    218
    built this car but lost interest and lost storage space for it so I'm going to sell it
    83 Monte Carlo SS LSX Swapped heads/cam
    -car is a true SS
    -fresh built 5.3 LM7 motor
    -243 heads ported/polished/milled down to raise compression with .660 valve springs shimmed
    -COMP CAMS 232/234 110LSA .595/.598 cam
    -LSX truck accessory drive
    -Holley intake manifold
    -Holley 670 carb with electric choke and vacuum secondary
    -vacuum pump with comp cams vacuum canister
    -1-7/8 Long Tube F body Headers into a custom X-pipe dual exhaust thru (2) 3" black widow widow maker exhausts dumped by the axle
    -MSD LSX box
    -new plugs, wires, coils etc;
    -new gas tank
    -champion 3 row radiator
    -holley fuel pump/ regulator
    -brand new (20 miles on it ) hughes performance TH350 Reverse manual valve body transmission
    -hughes GM 30 HD torque converter 3k stall
    -custom auto meter shadow box/gauge cluster
    -a/c delete heater box
    -new blower motor & resistor
    -new window motors and door lock actuators
    -new B&M pro ratchet shifter
    -new white vinyl pro car rally seats (match factory rear seats and blue/white factory interior
    -all exterior lights work (headlight, taillight , blinkers etc[​IMG]
    car has minimal rust, frame is strong painted engine bay with chassis saver before putting drivetrain in
    car is on wheels with brand new tires, rear tires are MT ET STREET drag radial
    car is FAST
    The interior that has to be put back in is the factory GM blue/white and blue carpet and brand new pro car white vinyl rally seats, the car has 1 seat in it and you can drive it
    what the car needs is a carpet, to bolt the seats in (driver seat is bolted in) put the rest of the interior back together, a fresh paint job and to be driven !
    asking 12,999 slightly negotiable I am into this car for over 15k so no low balls please text me at show contact info test drive for serious buyers
    don't need to sell it just testing the waters... my loss is your gain !
    message me on here or text me (917)-780-2043
    willing to trade for LS f-body car
    video of the car running /doing a pull sounds mean and fast IMG_6737.jpg IMG_6738.jpg IMG_6713.jpg IMG_6626.jpg IMG_6247.jpg IMG_6027.jpg IMG_6029.jpg IMG_6211.jpg
  2. 6spdg37s
    Oct 21, 2016
    372
    218
Loading...
Share This Page
