No brake lights
two90west
227
16
chicago
I go to the garage start my car car up and I see I don't have any brake lights I checked all the wires and checked the fuse panel I have power just no lights. All my turn signals work but when I turn on the lights my gas gauge and my speedometer shuts off. My car is a 1983 regal, please help me. I hate electrical problems :evil: :evil:
Bowiemontecarlo86
693
16
Tampa fl.
You mean your lights in your dash turn off or your gas gauge and Speedo stop working?
two90west
227
16
chicago
did that still no lights, checked the fuse panel i got power there but none in the back when i push the brake switch. the diagram helped but still no lights.
two90west
227
16
chicago
gas gauge and speedo stop working, but when i turn the lights off they come back on.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I think the problem is in the turn signal switch. Check the dark green and yellow wire on the connector you'll find on your column for current when the brakes are applied. If you have non then the turn signal switch needs to be replaced.
two90west
227
16
chicago
Thanks guys but I just took it to my local mechanic I should know something in a couple of days. When I find out what's the problem I will let the gbody world know.
two90west
227
16
chicago
Pontiacgp you were right it was the turn signal switch the local shop put it on for lunch 20bucks.
