No power steering after box swap and pump rebuild - '80 Malibu
Shackleford
8
2
I swapped the factory box in my '80 Malibu coupe with a used box from a Grand National and rebuilt the pump. The "power" part of the power steering is not working and I have a few questions about how to narrow down the problem before I start swapping out parts.
I rebuilt the pump and replaced both the pressure and return hose. I bled the system by turning the steering lock to lock several times with the engine off, then with the engine on until the fluid level stabilized and there were no longer any bubbles in the fluid.
I believe the pump is the original unit from the factory V6 (car was swapped to a 305 before I bought it). The new used box came from a reputable seller on eBay who claimed it was tested before shipped. There are no leaks and no abnormal noises.
My first question is, how can can I determine if the problem is in the box or the pump other than swapping back the old box?
My second question, is it possible that nothing is wrong with the pump, but it's just not the right spec for this faster ratio box and I need a different pump?
My third and final question, I replaced the hoses with part numbers for a 305 car rather than a V6 car. Because of the shape of the hard line portion (which appears consistent across all part manufacturers) the pressure line forms an upside down U-shape which is higher than the reservoir. Could this be trapping air and preventing the box from receiving pressure? https://i.imgur.com/1ldYkgO.jpg
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
are you sure you got the o rings in the right place in the pump?
Shackleford
8
2
Yes, because initially I didn't. The pump was leaking at the union nut, so I took it off and found I did have the o-ring in the wrong spot so I fixed it and put it back on. The leak went away, but the performance did not change.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I'd take it apart and redo after you watch this...
Shackleford
8
2
X2 Also, which valve is in the pump?
I'm not sure, how do I check?
Thanks for the link, that was more detailed that the videos I watched when I did it. I didn't see anything obvious that I remember doing differently, but who knows, I have a spare seal kit so I guess I'll take it off and try again.
So the arrangement of the pressure line definitely isn't an issue?
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
this is what you lines should look like......if the lines are on reverse the steering wheel will violently go back and forth. When you were bleeding the system did you feel any unevenness in the steering?
ItsnotaGN
662
1,142
Colorado
If you had the vanes out of the pump, make sure they are in correctly. They will be flat on one side and slightly rounded on the other. The slightly rounded side faces outward. If they are in backwards they will not seal and create flow.
  • Informative
Shackleford
8
2
The wheel feels slightly lighter when turning back to center from full right hand lock, but it's not violent and I confirmed the lines are hooked up to the right port, but my lines are a different configuration that what is in your pic.
Shackleford
8
2
This sounds promising because I did not notice this when I put the vanes back so there is a good chance some of them are in there wrong. Guess I have to take the pump apart.
