MONTE CARLO No power to horn, courtesy light, or radio
M
mr84monte
19
14
#1
Many years ago I started my drivetrain swap, and pulled the computer out of my 84' SS, and also at the same time pulled the aftermarket stereo out to install a more modern one. The drivetrain swap was finished two weeks ago, and when I got it back I noticed that the horn, and courtesy lights didn't work, and thinking that this was because I pulled the radio fuse and didn't think much of it. But this weekend I was working on the stereo, and got it wired, but went to fire it up, no power (I put a good fuse in). I plan to go over schematics when I get home, but I'm posting this to see if anyone might have had this happen to them and can tell me a good place to start.
C
carl
10
6
#2
missing a ground somewhere ? got to get that test light out there & see what's up
M
mr84monte
19
14
#3
Would removing the computer wire harness, have an effect on ant of these items? They only thing that I've been able to figure out so far is more items not working such as the power locks. The courtesy light fuse was blowen and blows as soon as a new one is put in, so it appears that there is a short somewhere.
One More Pontiac...
One More Pontiac...
15
40
13
CT
#4
Disconnect the power lock relay behind the right kick panel then see if the fuse still blows...
Dayzedandkonfuzed
Dayzedandkonfuzed
329
138
Anglemont, BC
#5
M
mr84monte
19
14
#6
Yelp good news and bad. Bought a new fancy circuit tester on Amazon today and after it was delivered, I went to the garage, and thought hmm I didn't actually check the amps to the circuit. So I plugged in the multimeter and it read 11 amps (20 amp circuit). So naturally I say wtf and plug in a different tester and no short? After blowing 5 fuses in a row, I plugged in a new one and now everything works. Obliviously the bad news I don't have any idea where the short is, so it could come back at any time, and even more bad news is that I didn't get to use my new $70 circuit tester. Tomorrow I'll go out and wiggle more wires around to see if I can short it out again.
Similar threads
