There is no fusible link in the starter wire. The red wires with the fusible links feed the fuse box. There is a purple wire that goes from the ignition switch to the S terminal on the starter solenoid that gives power to the solenoid to do it's
There is no fusible link in the starter wire. The red wires with the fusible links feed the fuse box. There is a purple wire that goes from the ignition switch to the S terminal on the starter solenoid that gives power to the solenoid to do it's job.
iMisspoke then. So do you think it’s the ignition switch? I’ve seen things mention neutral safety switch and starter relay. I’ve also seen there is no neutral safety switch on gbody cars. And I don’t see a relay or fuse for the starter. Either way the cable has no voltage. Which is weird because it did before iSwapped the engine and haven’t messed with it. But this is wiring and things happen.
