Non G body question
Wageslave
1,750
3,341
2.7s are a sh*t design. If it is sludged real bad, you may have low oil pressure that can't drive the timing chain tensioner out with enough force to keep the chains from slapping. It would be worse at idle, and could be from a blocked oil pump pickup or a worn out pump. If you see the oil light flickering at idle, that is a good sign that that's what's going on. I went through this on my ex-wife's old Intrepid.
My advice, get rid of it ASAP.
Jorge1958
380
214
Columbia City Oregon
Oh i want to unload this thing ASAP. I have no oil pressure lights flashing in the dash. There are no trouble codes. Its wore out. Im sure the timing chains and hydraulic tensioners are shot. My only real concern is why it starts rattling real bad and dies.
350-G
May 2, 2015
61
70
GA
. Having owned my 04 Ram since new. I have learned that later model Dodge cars and trucks have two common problems. Egr and throttle body. The o-ring at the end of the egr tube will suck air, and the throttle body will need cleaning or need Replacing. A $3.00 o-ring maybe part of the problem. If that don’t help I would take the throttle body off and clean with TB-cleaner and see if that doesn’t helps. Just don’t spray cleaner down in the intake. That will just wash all excess oil inside the intake down to the cylinders and cause more problems. Hope this helps. F4589E92-CDCD-4300-991B-470D0B199CD8.jpeg
Wageslave
1,750
3,341
If your tensioner are loose enough, I could see it getting cam correlation errors and the computer shutting down because it doesn't know when to fire the spark plugs. That should leave a code in the computer, but cam and crank sensor related errors don't always leave an error behind.
Jorge1958
380
214
Thanks for the info. That could be the reason for the dying. I will chk it out
