Ok so following the saga of me chasing down a mild engine tick. Chevy crate 350, hydraulic lifters, flat tappet cam.
Things not causing it: Transmission/torque converter, water pump/alt/ps/a/c compressor. Those I ruled out by disconnecting them.
I adjusted the valve lash following what seemed to be a simple method. Rotated engine till just after intake closes, turn rocker nut until pushrod stops spinning, turn rocker nut one half turn to set preload. Continue following firing order as each next cylinder predictably had a the intake side open already. Seemed easy enough. Car starts and runs but now sounds like a diesel. Clacking EVERYWHERE. What have I done? Suggestions welcome.
