NV3500 5-speed swap
Wageslave
1,750
3,341
I have been gathering parts for a manual swap into my '83 El Camino since February, and I have just got the e-mail saying my SickSpeed Monte pedal kit will be arriving by Tuesday. This means I have finally acquired everything I need to get my NV3500 put in.
On a side note, there is an amazing variety of GM and custom parts going into hooking this motor to this transmission. This is the list of parts I THINK will go together to make this work:
2002 S10 - M50 NV3500 5-speed transmission
1990 Chevrolet 1500 - Flywheel
1998 Chevrolet 1500 - Clutch Set
2002 S10 - Concentric Slave Cylinder/Throwout Bearing
2002 S10 - Hydraulic Hose
2000 Camaro - Clutch Master Cylinder
SickSpeed Monte - Clutch Pedal Assembly
G Force - Crossmember and Frame Extentions
There were a few easier ways to do this, but I wanted to use a V8 flywheel and clutch set instead of using the V6 flywheel and clutch set out of an S10.
oldsmobile joe
2,067
3,053
mpls
sickspeed has a nice pedal setup. i have one in my brown cutlass. word much better than the psi pedal i used before.
joe
Wageslave
1,750
3,341
joe
I hope so, my poor knee can't hardly handle a stout clutch anymore.
I will be picking up some from the dealer after I get it set in. If my last transmission pull was any indicator, there will not be a drop left in it by the time I get it angled into the car.
Wageslave
1,750
3,341
He seemed pretty cool over e-mail, and I did like the pictures of the car on his site.
Wageslave
1,750
3,341
I got the old TH200 out of the car this evening, and as tradition my hair is now thoroughly conditioned with ATF. It has been a good transmission in the time it was there but it was leaking fluid all over the place. I also found a rust hole or two that were not there before, including one that is directly over the differential.
I did end up getting a 1998 Chevrolet Truck slave cylinder and installing it instead of the S10 unit that I had originally planned. The slave cylinder that came with the transmission had a throwout bearing that was a different style than the one from the parts store.
I did drop the transmission out from below, but it was a PITA and I am still undecided whether the engine will come out for putting in the new transmission.
Wageslave
1,750
3,341
I did get some progress made today before work. I had to pull my aftermarket cruise control setup out, as all of the wiring went through the firewall at the cruise control hole. I probably will not put it back in since I rarely ever used it anyways.
I got my pedal cage out of the car and have the clutch pedal attatched to it. I still have to cut the brake pedal down, but I need new pedal pads to measure off of.
My bracket that attaches to the brake booster rubs against the inner fender slightly. I will probably just use a torch and an old ladle to make an indention in that part of the fender.
The automatic shifter linkage and handle has been taken off of the car. I may wire around the park/neutral switch so I will have reverse lights, but that will be after I get it rolling on its own.
Hopefully after work I will get my new trans mocked in place so I can cut a hole in the tunnel.
Wageslave
1,750
3,341
IMG_20170907_134010.jpg IMG_20170907_134010.jpg IMG_20170908_133446.jpg IMG_20170907_121111.jpg
I got a little more progress made before work. I got my Camaro master cylinder mounted on the bracket and installed on the car. It still needs a little trimming around where the hole goes in at the firewall, but I haven't put the pedal cage back on yet so it will just slide back out of the way.
I had to go junkyard shopping for pedal pads, as the Dorman part is not in parts stores for some reason. I also got a reservoir out of a cavalier as all the camaro ones in the yard were trash.
Hopefully I will have the pedal side of things buttoned up tonight.
Wageslave
1,750
3,341
Some more progress this evening. The pedal side of things is complete and the slave cylinder has been bench bled.
I also got the automatic flywheel removed and the manual (heavy as hell) flywheel installed. I ended up getting the clutch and pressure plate installed before I called it a day, but it getting closer.
