NVU TECH FORUM- anything gauge related please ask!
New Vintage USA
Supporting Vendor
Silver
Oct 3, 2017
39
42
47
DETROIT
www.newvintageusa.com
#1
We decided to start this thread so we could hopefully lend a hand when it comes to instrumentation, NVU brand, stock or otherwise. We will do what we can to help out!
zdeckich
466
228
Fort Worth, TX
#2
Do you sell the panel/shadow box for the gauges for a 78 Malibu sweep style only?
New Vintage USA
Supporting Vendor
Silver
Oct 3, 2017
39
42
47
DETROIT
#3
zdeckich
466
228
Fort Worth, TX
#4
I mean just the housing the gauges go in with no gauges.
New Vintage USA
Supporting Vendor
Silver
Oct 3, 2017
39
42
47
DETROIT
#5
No, Sorry the mounting brackets are only available in the gauge kits. The brackets are designed for NVU instruments only ;other brand gauges may not fit due to the thicker bezel sections/slight size differences. This kit is really tight with fitting the gauges and back clamps next to each other
Thanks
1bad79
632
230
Allendale mi
#6
So your 78-88 cutlass gauges are they compatible with the stock fuel sending unit and speedo cable
New Vintage USA
Supporting Vendor
Silver
Oct 3, 2017
39
42
47
DETROIT
#7
Here is a link to the cutlass kits for more detailed information:
http://newvintageusallc.mybigcommerce.com/78-88-cutlass/
All of our kits for GM include a fuel gauge with a 0-90 ohm input (stock GM). The mechanical speedometers are standard aftermarket setup with a 1:1 drive ratio and a 5/8-18 male thread, .104"x.104" female drive tang input.
Electronic speedometers will require an electronic speed sender or PCM input to operate. We manufacture cable replacement style speed senders and GPS speed senders. All NVU electronic speedometers can also operate from GM PCMs and GN OE speed senders
Thanks!
1bad79
632
230
Allendale mi
#8
And if I'm reading correctly the oil and water gauges are also electronic not mechanical,correct? looks like a cool set up and I'm in the market this is one of my projects on my winter list
New Vintage USA
Supporting Vendor
Silver
Oct 3, 2017
39
42
47
DETROIT
#9
Yes we only use electrical, patented, mil-spec air core or our stepper motor line in all of the instruments. No tubing to leak. the only mechanical we do are 3-3/8" speedometers and some vacuum/boost gauges.
Dec 28, 2015
2
37
#10
What part would I need for the programmable speedometer to work with my TH-350 mechanical output. I am looking at purchasing a gauge kit for my 1980 Malibu.
Similar threads
Classic Truck Consoles Dixie Restoration Depot GBodyParts Mike's Montes P-S-T UMI Performance
