Hmmm, just reread my post and oddly enough failed to find any sugggestion that he get rid of the CCC system as you describe it. In fact one of my primary comments was that, if the system is still working properly, that he keep it.
As for my contention that the OBD 1 unit is essentially an idiot, consider, that yes it can be read but only to a limited degree. There is no way to visit it and adjust or alter its configuration. yes it does govern the activities of the carburetor and distributor but within such a limited range of adjustability that for all practical purposes what the factory set as defaults pretty much have to be retained.
Further, I do agree that simply ditching the ECM without also replacing the carb and timer with independently functioning units is absolutely going to cause issues.
Where I was headed was in the direction of the O-2 sensor and whether or not the vehicle actually came with one as delivered from the factory. I am not about to say that it didn't come with one as first assembled but I would point out that there are all too many case of owners opting to delete components when they broke or became unavailable for replacement as a cheap option to shelling out big $$$ to find a replacement that is no longer made or has been withdrawn from dealer shelves for disposal.
Also not here to criticize GM but if you buy a new version of anything they make, better determine rather quickly what wear parts have short life spans and stock up as five years or so later, you may visit your dealer only to find out they no longer carry that item and the aftermarket has not yet picked it up.
For this owner to consider re -creating the O-2 circuit he, at least, has to determine if his ECM has a provision, i.e. plug in, for the necessary wiring, and if his present exhaust head pipe has a bung for the sensor itself. As you point out the sensor is available in many versions with various harness configurations. It is entirely possible that some remnants of the original circuit are still present but how much labor and repair is it going to take to rehabiliate them? This is 37 year old technology he is having to work with. Replicating the stock OEM configuration is a definite goal but is it practical?
