Odd groaning noise on braking
rogus
312
85
I'm getting an odd groaning noise when apply the power brakes. It almost sounds like it's coming from under the dash. The brakes still work but every once in awhile the brake peddle is a little slow to return to it's normal position. I'm thinking this is the brake booster going bad. Any advice here would be greatly appreciated.
Clone TIE Pilot
3,857
2,608
Galaxy far far away
If you have a Mityvac you can test to see if it holds vacuum.
565bbchevy
9,613
12,678
Michigan
Recovered enough from surgery to replace brake booster. Everything is better now.
I'm happy you fixed it and it's nice when someone comes back and finishes a thread with the final result.
Clone TIE Pilot
3,857
2,608
Galaxy far far away
