Friends, I have had my 85 Cutlass Supreme with the 3.8 V6 for about 5 months now, I seem to have a random issue I can not track down. Every once in a while, I will start and drive the car, then park it, run back out and jump in to start it again and it just cranks...wont start? It almost acts like it is vapor locked? It will turn over and sounds good minus firing up. Then after 10-20 minutes, it will fire but will run at a very low idle for a moment and lots of black smoke comes from the exhaust, appears to be from fuel that loaded the carb as after 10 seconds it is running fine and zero smoke. This is an intermittent issue and last time it occurred, I checked and I am getting fuel so that's not the issue. Well the other day for the first time, I fired it up, drove around my block about 1/2 mile, flipped a u-turn and it just shut off? First time ever doing that! After about 30 mins of trying to start...nothing! Just cranking away! When it shut off, still had full electrical, no issue there. Got a tow strap and towed her home, tried to fire it up and boom, it started but ran like crud and smoked first few seconds. My thought is that it is an issue with spark. Would you guys agree or what else should I check?
