bent1973 said:
Much appreciated, thank you. I'll begin the hunt for it.
You are probably not going to find it in a dye, you can't just use any paint.
You need a paint with adhesion promoter or dye.
There are probably close matches out there with Duplicolor, the GM code is Dark Camel Tan 62.
Not sure if Gbodyparts has it but I think the owner is in jail so getting something from them might not be possible.
http://realoldspower.prophpbb.com/topic6989.html
You can take the codes I gave you and go to any local paint shop and they can mix you up a spray can.
I tried paintscratch.com and wound up with a bad batch.
After doing an internet search I found a bunch of displeased customers.
I contacted their customer service and it was an automated phone call, I left a message and a new can arrived 10 days later after filing a PayPal dispute, I have not tried it...
