Oil/Choke light 1982 Cutlass
T
TommyCaspers1488
n00b
Jan 3, 2019
My oil/choke light comes on after 15 to 20 min and only when I come to a stop. It goes off again as soon as I go. I have 1982 cutlass with the 3.8 v6 any ideas as to what could be causing this? Oil was just changed. Please let me know what I can do to solve this issue Thanks!!!
Thread starter Similar threads Forum Replies Date
MalibuDavyou5 Oil Choke Light. Engine / Swaps / Driveability 16
Doug213xrj Cam break in oil ? General Discussion 18
Mikey REGAL Oil leak Buick Regal / T-Type / Grand National / GNX 12
69hurstolds Peak oil- the world will run out of oil in 10 years. Drive 'em while you got 'em OFF TOPIC 3
ssn696 Costco Synthetic Oil On Sale General Discussion 11
J Ls Swap Oil Pan Hitting Frame on 84 Monte Carlo ss G-Body LS Swap 7
MalibuDavyou5 Oil in the Radiator. Cooling / Heating / AC 33
Reddzedd Ford 9" recommended gear oil? Transmission / Rear End / Driveline 8
GBody.co.uk CUTLASS Change THM350 Oil Cooler Lines Transmission / Rear End / Driveline 5
nummbr7 Batwing oil pan G-Body LS Swap 28
dickeymoore Autometer oil line???'s General Discussion 7
84regalbuick 84 regal, 350 Chevy no oil through push rods G-Body Build Threads 41
MrSony New Summit Racing ZDDP Oil General Discussion 19
Injectedcutty MOBIL 1 ON SALE!!!!!!!!!!!!!!! General Discussion 12
dickeymoore Best 1 piece oil pan gasket???'s Engine / Swaps / Driveability 13
dickeymoore What oil dipstick Engine / Swaps / Driveability 11
Bonnewagon Oil on head bolts? General Discussion 24
Bonnewagon Oil pump pickup screen tool How-To's / Knowledge Base 13
Bonnewagon Fresh engine- what oil? How-To's / Knowledge Base 29
565bbchevy Unbelievable oil change General Discussion 6
TURNA OLDS OLDSMOBILE Oil pump Choice...??? Engine / Swaps / Driveability 31
Gwarren79 The impending Big Auto / Oil implosion explained (2018) General Discussion 68
Bonnewagon Tapping oil drain plug hole oversize Engine / Swaps / Driveability 4
C Slightly O/T-Buick 350 oil pan. OFF TOPIC 6
O trans oil cooler line size? Transmission / Rear End / Driveline 1
MrSony Installing AFR gauge on an Oil Burner? General Discussion 54
Tony1968 Oil cap minus tube on stock valve cover G-Body LS Swap 0
B how much gear oil General Discussion 7
tc1959 Interesting artical on Zink additives and off the shelf oil. General Discussion 24
xitabl442 How much oil? Cooling / Heating / AC 0
TURNA Oil Pump Bolt Size General Discussion 9
GermanDude Oil pan Engine / Swaps / Driveability 12
TURNA Olds oil pan Milodon 30765 General Discussion 18
TURNA RUST IN MY NEW OIL PAN!!!!!!!!!!!!!!!!!!!!!!!!!!!!! General Discussion 32
TURNA OLDs oil pan gasket General Discussion 32
TURNA Olds oil fill tube General Discussion 10
FluoFerret Oil Coolers Cooling / Heating / AC 62
azmusclecar Is there a way to test the oil pressure gauge? Electrical / Ignition / Starting 24
dickeymoore how many quarts of gear oil Transmission / Rear End / Driveline 3
ramirezantonio1409 86 Cutlass Starving For Oil Oldsmobile Cutlass / 442 / Hurst/Olds 4
BuickBroke$ REGAL Turbo LS oil pan mods G-Body LS Swap 7
Emhendo How Much Oil Does an 86' Cutlass Supreme Hold? Engine / Swaps / Driveability 11
84Oldz Oil pressure sending unit buick 3.8 v6 Engine / Swaps / Driveability 10
spicercars Oil Engine / Swaps / Driveability 7
DROLDS84 OLDS Choke problems Electrical / Ignition / Starting 22
S wire electric choke General Discussion 14
Jmac Stalling after choke opens Engine / Swaps / Driveability 14
Bonnewagon AAAARGH!!! Spit-cough- choke OFF TOPIC 12
Bri guy electric choke wiring Fuel / Air / Boost / Emissions 67
Eddie Cutlass CUTLASS Another tail light/turn signal post 🤓 Electrical / Ignition / Starting 12
Similar threads
Oil
