Oil pan gasket
Bri guy
845
225
Does the oil pan just drop out once unbolted? Or are their other things in the way I need to remove? Been thinking about putting on a new gasket
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I would clean the engine first to see where it is leaking from. It could be the bolts on the pan need to be tightened or it could be the valve covers are leaving and running down the engine. Personally I don't trust shops to do what they need to do.
Bri guy
845
225
I will check the covers when I get home. I usually try to do things myself. But If I think I will struggle or get stuck in a bind, I will bring it somewhere. I been doing alot so far to the car, don't want to struggle anymore!
