Oil Pan & Gasket
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
This winter I'll be switching out my Moroso 7 quart oil pan to a stock SBC pan so I'm wondering what brand I should get and the best gasket to get that does not leak. Also what's the best 1 piece rear seal that will not leak?....
Thanks
lilbowtie
3,460
3,965
Canton Mi
I use nothing but Fel Pro
1320John$$$
951
2,043
Pennsylvania
This one used it a 100 times never leaks fit left and right hand dipstick along with one and two piece rear main seal 25$ Rockauto
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
looks like the gasket is taken care of. I like the Fel Pro but I was interestred if there was something else in the market I was not aware of....for the pan what is made is the US or is that asking for too much?
1320John$$$
951
2,043
Pennsylvania
cardone and dorman work dry fit them first summit and jets brand run i’ve had zero luck with them
8,819
7,766
Melville,Saskatchewan
I wish someone would make a gasket like that Felpro for the Olds V8. Hopefully you have better luck with the sbc pan. The Moroso and Milidon pans for Olds have had cracking and leaking issues lately. The Canton pans are more money but worth it.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I found another Fel Pro that is more expensive that I plan on getting, it has one opening for the dip stick....Fel Pro 1886
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
maybe a change of plans, cruising through the local kijiji ads I came across this for $85...the pan and gasket has good reviews, filter I won't use.
ATP Graywerks 103033 Oil Pan
MAHLE OS32496B Oil Pan Gasket
ACDELCO PF454 filter
