Oil pan hole
I-AM-JD
Jan 7, 2020
65
15
8
Sacramento CA
Everyone I have a question I have a 1980 Buick Regal 3.8 L and oil pan has a hole that's not threaded and is not drain plug hole can anybody enlighten me on what this hole is for? I appreciate it thanks.
Turbolq4
1,732
4,207
Nampa Idaho
Possibly a low oil pressure sensor location?
Or an exit location pre laid out by the factory connecting rods...
Ribbedroof
4,892
6,944
Wellston, OK
Side? Bottom? In sump or somewhere else?
Dipstick entrance?
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
Is it reinforced around the hole? I've seen 1987+ SBC oil pans with a hole about halfway up from the sump for a level sensor. If it's reinforced, you can see if it is close to a tapped hole size and fit it with a plug.
Or, add a turbo kit to the engine and use this hole for the turbo oil return line!
I-AM-JD
Jan 7, 2020
65
15
8
Sacramento CA
I-AM-JD
Jan 7, 2020
65
15
8
Sacramento CA
So it's on the bottom of the oil pan that's not threaded or reinforced occasionally it does leak. do you think I should plug it? I was going to but I didn't know if it was supposed to remain open like that.
500/600
1,167
2,638
West Virginia
I’d leave it open.
Ribbedroof
4,892
6,944
Wellston, OK
Uhhhh, yeah. If it leaks, plug it. I can't imagine that it doesn't leak all the time if the oil level is correct.
