Oil pan
GermanDude
GermanDude
21
Germany, Brandenburg
Hey folks,
I'm actually changing the oil pan gasket. Therefore I have to lift up the engine. Can anybody tell me how to do?
Thanks
TURNA
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,007
Socialist NY
What car/engine?
Take out the motor mount bolts
put a piece of a 2x6 big enough to cover the sump of the oil pan
floor jack under the oil pan with the wood on the pad, jack up engine
put 2 pieces of 2x4's one on each side of the engine between the 2 motor mounts, release jack
now the engine should be high enough to drop the pan and clear the Kframe
you will also most likely remove the timing cover along with everything in front of it, to ensure a proper seal.
Reactions: fleming442
GermanDude
GermanDude
21
Thanks for your answer.
I have the problem that the bolts of the motormounts are loose but the engine doesn't move. I dont know why...
TURNA
TURNA
Jul 24, 2009
10,007
Socialist NY
it should only be 2 long bolts and they have to come out not be loose
TURNA
TURNA
Jul 24, 2009
10,007
Socialist NY
Still dont know what car and engine u have................
olds307 and 403
olds307 and 403
5,489
Melville,Saskatchewan
The factory service manual actually shows undoing the engine mounts and lifting on the harmonic balancer with a floor Jack. Also the crossover pipe will need removed. Buy a block off plate and put the crossover pipe, along with the factory exhaust under the bench. A custom bent 2.25" or 2.5" dual exhaust will add a measurable gain in power.
TURNA
TURNA
Jul 24, 2009
10,007
Socialist NY
He is in Germany, exhaust may not be that easy
olds307 and 403
olds307 and 403
5,489
GermanDude
GermanDude
21
Hey Folks,
i lifted the engine whith a engine lifter.
It was a great expense to replace the Oil pan gasket. Until now i never had to lift the engine to rplace the oil pan.
It was also necessary to drill holes in the exhaust manifold for the cross pipe.
But now the oil pan is dry :eek:)
Thx
