Oil pan
MY6.2SS
144
87
Hello, new to the group.
I did look for the answer to the question that I am about to ask. Had no luck.
I built a 6.0 for my S10 and sold that truck yesterday. So now I am putting it in my 85SS. The oil pan that
is on my 6.0 is the ....."GM Muscle Car Oil Pan Kit (P/N 19212593). This is also the same oil pan used on LH8 V8 equipped Hummer H3 Alpha’s and Colorado’s."
Will this pan work, if so what mounts do I need to get. If not what is the best pan and mounts to get?
Thanks fro your time and help, David
Turbolq4
1,732
4,207
Nampa Idaho
That's the pan I have in my car. It still hangs below the cross member but it's not bad enough to keep me up at night. It's been in there for 5 years now. If your car is lowered or you want to move in that direction then I would get something with more clearance. Mine is at stock ride height and it works fine. As far as mounts go, I assembled both halves and put them on the engine. Set it down in the car, moved the powertrain to where it worked, welded the lowers down. I could have marked the frame and drilled it but that would have taken an extra hour of my life away.
Reactions: 4 users
MY6.2SS
144
87
Thanks for your help.
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
I used an gen1 CTSV oil pan on mine
64nailhead
Goat Herder
Dec 1, 2014
5,697
12,185
Upstate NY
I'm using a stock SUV pan from a Gen4 - hangs down about an 1" below the crossmember. I'm with LQ4, I'm not lowering the car and I'm not loosing any sleep over it. If you want the best setup, then use the Holley pan. The issue with the Holley pan is the do re mi AFAIC. Holley pan - about $300, stock SUV pan - free.
Free is for me
Streetbu
Know it all, that doesn't
3,733
11,573
Central NY
BTW, the one I posted above, is actually sold and delivered by Holley out of Kentucky but comes in a plain white box. It is powdercoated black and has all the associated hardware and everything.
Reactions: 4 users
Tony1968
2,319
5,112
NW Indiana
This says it's good for a 4.25 stroke so it's going to be very close to cross member. My pan is for stock stroke and it's got clearance but not much.
Just an FYI unless someone has run it without issues. Darn good deal though
gearheaddrew
Oct 29, 2019
62
122
33
Bay City MI
After reading a ton of other build threads this is what I ordered.
CTSV pan
Spohn frame mounts
F body LS engine side mounts
G-force crossmember for 4l60e
Depends on if you plan on using AC, want to run the stock truck AC pump, etc.
