Oil pressure gauge pegged over 60 psi, where to begin to find problem
azmusclecar
601
307
i Just redid my dash and all my gages now work. EXCEPT the oil pressure gage.
Before I go any firther I'd like to knwo some steps to find out if this is an electrical issue, or a sending unit issue
or a gauge iussue.
I seem to always choose the wrong plan of attack.
So can someone point me in the right way to diagnose where this problem lies.
I know the oil pressure sending unit is on the front of my Olds block which at least makes it handy to replace if need be.
So where do I begin?
Huen79H/O
Jun 5, 2018
74
161
33
When I bought my 79H/O my gauge read 60 psi. I would bet that the sending unit is shorted. Here are some repair instructions
1. turn key on do not start check gauge does it read 60 psi. If so sounds like sending unit.
2. Unplug sending unit turn key on gauge should read 0 psi. If so replace sending unit
Following this should repair your gauge
azmusclecar
601
307
Ahhhhhhhhhh, this makes sense, let's see what happens....
azmusclecar
601
307
I unplugged the electrical connection to the oil pressure sending and turned the key on and it still read 60.
Where is the sending unit for the oil pressure gauge or is it IN the oil pressure sensor ITSELF?
Huen79H/O
Jun 5, 2018
74
161
33
You might have to ground the sending unit wire to make the gauge read 0.
If you ground it and it reads 60 then it is wiring or gauge
azmusclecar
601
307
Ill give it a shot tomorrow.............nothing to lose, thanks for your suggestions and directions...........every little bit helps.......(y)
