I changed my idiot lights to the rally pack analog gauges...gas gauge works, volt meter works, changed water temp and it appears to work (runs around 220) and now I am stuck with the oil pressure switch. I bought a single wire sending unit but I only see two wire gauges (two of them) on the drivers side near the distributor... is one of those the oil pressure gauge for the idiot light? Is the other a fuel pump shutoff? The oil pressure guage reads 80 pounds...I figured if I unplugged the right gauge that the needle would drop back to the rest position... didn't happen now I don't know which unit to replace....HELP!!! You can call me at 727-452-4814 Thanks!!
