It was a PITA when I added the oil pressure gauge sender on mine. Unfortunately that is the only place to tap into. Not much room to work at all. Biggest challenge was getting the senders in the right location and not leaking. When done, I was kinda surprised at how much oil pressure the engine had.
Probably nothing. Buick engines are notorious for having low oil pressure. Not really a bad thing, as long as it's at least 10psi per 1000 rpm and raises fairly quickly with RPM, it will be fine.What did you end up doing to lower the pressure ?
