OP. Its in the bottom of post 3 linking to
maliburacing
- 2 separate sensors with 2 separate pickup locations. The one behind the distributor is indeed linked in with the choke. 1 line in, 2 lines out to the light and the choke. The other is down by the Oil Filter as on Jareds picture above. Not all the blocks were machined for this, if yours is not then you need to tee off behind the distributor.
Jared - please be cautious with those brass fittings. I had one let go years ago when I tee-d off behind the distributor and it broke making a huge mess and leaving me stranded. A couple of friends have mounted the sensor on the wheelwell tucked under the Master Cylinder using braided line with a 90deg fitting to clear the clutch linkage
https://www.amsperformance.com/cart/AMS-Remote-Oil-Pressure-Sending-Unit-Line.html
I am sure Jegs or Summit has something for much less dough
