I was wondering what you guys use, or suggest using as far as a suitable oil pressure sending unit for OE electric gauge. I managed to pick up an oil pressure sender and water temp sending unit today to work with my factory gauges.
I've already replaced the water temp sender, that was easy. Just had to add an oversize adapter. The oil pressure sender is another issue entirely. I removed my mechanical gauge with capillary tube. I had it installed at the back of the engine next to the distributor with a 1/8" nipple and a T-fitting and oil light sending unit.
Well, the new sending unit doesn't quite fit in that area. The plug above the oil filter had never been tapped...so it looks like it would have to be installed at the back of the engine like it was.
So I'm in a bit of a quandary here.
I recall on my old Porsche 914, I added a VDO double pole sender. It wouldn't fit in the same area as the old sender, so I purchased and installed a VDO adapter hose to sort of remotely situate the sending unit.
I'm wondering if I'll have to resort to something of that nature. BTW, I looked up the sending unit for an '81 El Camino with V-8 and factory gauges.
Sorry about the long winded explanation. I'd like to know what you guys recommend. Is there another type sender that fits better in that tight area?
I just changed out my dash for a GP unit using OE gauges and tach. So I'm in the middle of getting it operational.
