Don't know why I didn't think of that - hahaYou probably considered this but can't you install the regulator in a different location?
abadwillys that looks good. but it may bring it to close to my intakeHaha i just ran into that same problem, i ended up mounting my regulator underneath the bracket, required some modifying of the bracket, My first idea was exzactly what you did, but i did not want to cut my filter, had to go with plan B..
yes the base is sitting were I want it and I will cap it off but I will still have to notch the air filterIt looks like you almost have it if the bace doesn't need to drop any further I'd find something to cap over it with like an old aftermarket center cap something round like that so air flows over it nice
this base is notched 360*Looks like you would have to trim the air filter too much, maybe you could try a drop base for a holley carb with notches for the fuel bowls? I'd second the idea of moving the regulator.
yes i thought about that, really don't want to but may be my only option.You probably considered this but can't you install the regulator in a different location?
Yeah, i didnt think about that, i have a 1" HVH Super Sucker Spacer, so i had the room
you may have to move the regulator
