Hi Everyone;
Thought I would make my first thread and see if you have seen this before. I bought a cutlass sedan with the 231 and t200 transmission. The T200 I know is not the most reliable I have heard but it does run well for this car right now. (I think)
As a background, the car sat for 3 or 4 years till I started driving it. It ran fine for a month or two but now I get this intermittent issue when driving up a hill, basically like it kicks out of gear and tries to stall (but doesn't). I pull over to the side of the road, she purrs just fine at idle. Give it 15 or 30 secs and away I go again.Car could go for 300 miles without a hitch after. Might not see the problem again for a couple weeks of daily driving in fact! (so odd).
First thing I thought was Fuel pump (as driving uphill, sputter) so I have one on order. I swapped the Fuel filter in the carb already, same random issue though. I know old gas and crap in the tank could still be an issue too (car sat for years) and with my sender not showing on my gauge, (gauge reads constant full, pins full when started) and cleaning the ground to the sender hasn't changed that. So I am swapping the sender too and cleaning the tank. All these parts are only costing me like 100 bucks anyway so why not right?
Transmission wise I checked the TV cable and its tight with WOT adjustment. Transmission has nice pink/red fluid and the old owner said he replaced it and the filter. Car shifts so smooth like butter. There is no Vacuum advance for these transmissions, so no modulator valve adjustments. I did read a TSB about pre 1988 T200's having a poor shift solenoid from the factory and there is a replacement one. (Symptoms being car stalls when going from Park to Drive or Reverse.) Mine does this until she is warm too so its on the list, but the TSB did not mention that was a symptom while driving.
Any road, the car has only 130,000km (or 80,000 mi) original miles and no rear frame rust at all. Hence why I am trying to service it like she'll be with me for a good long time. I have an 83 Olds (same drive train) with a poor frame for a parts car as well, but I am using new parts for these items. I just wanted to know if anyone else has had this issue and is there something else I should check? I have had SBC's and T350s since birth pretty much so this Buick231 and T200 stuff is not the same animal. But it is a great setup (and its cheaper on fuel than my truck
Thanks for reading
EDIT: Should also mention, the car had the sputter problem recently, after car was warm and I had just filled the tank. Makes me think crud in the tank more, but don;t want to rule out transmission as the car purrs nice.
Thanks for reading
