Hey guys, I'm new to this forum and could use some help. I have a 1985 delta 88 body with an 83 or 84 Olds 307 in it. When I had the engine out I removed and blocked all the smog and emissions crap on it, looks too messy, and put an Edelbrock 1405 carb on it with a brand new vacuum advance distributor from an older 307. I've got the car running, but any time you load the engine she sputters horribly and tries to die. I set the timing at 20 BTDC around 1500 rpms with the vacuum advance plugged off and it helped, but she still runs like a 3 legged dog. This is my first experience with a carbureted engine, and I did rebuild the carb with the help of my old Automotive instructor to make sure I didn't miss anything. I checked vacuum at idle and she's only running about 11 in HG, which is way too low. Checked compression on all cylinders and they were good. Even replaced intake gasket and sprayed all around the carb base and intake checking for a leak. At this point I'm stumped. Did I set the timing incorrectly or do I have another problem that I'm missing?
