Hi,
My name is Waldo, I write from Santiago of Chile, yesterday I buy a one Oldsmobile Cutlass Supreme 1978.
It come with cruise control, floor shifter, a real NASTY 260 ci V8 engine with a THM200 transmission.
The car is a real original situation, It come with all A/C system, cruise control and original vacuum ports, sensors....etc
I have a some question.
I need lower an upper bearing from steering column (tilt).
It is posiible to put a 350 rocket engine with th350?
I need to buy a hardware (bolts) from upper and lower control arm, here in Chile has not exist.
I´m confused about the all the rear bushing , some have the moog part number to need to buy to repair rear suspension?
The car is so original that I would like to keep it that way.
I would like to change the cluster to a gauge cluster, some here sale one?
The car have rust in the rear window at lower corner , I need to know how remove the top carpet an remove the little window to remove the rust.
In the trunk lid come with a "congressional olds" plate, Someone know who is it?
Pictures!
Thanks and sorry for m bad english!
Waldo
Pictures!
Waldo
