Thanks lot!Just measure the width, pretty sure it should work.
They are easy enough to replace. The 260 specific Turkey Tray intake gasket is a different part number.
https://www.google.ca/url?sa=t&sour...ggqMAI&usg=AFQjCNFnc7ch8ypbOJy2ft6iDdIzuXOYJg
I used aviation sealant or gaskasinch around the intake ports, not necessary but I do it. What is necessary is RTV around the 4 corner cooling ports, both sides of the gaskets. I also use a tall bead of RTV instead of the supplied rubber end seals. The bead must be a 1/2" tall to seal the end seals on the wide Olds intake manifold.
