Olds diesel, sat for 8 years
Carson L W
9
19
#1
Just got a Cutlass Supreme diesel. Hasn't ran in at least 8 years but it was well taken care of when it ran. At first she wouldn't crank over, but I replaced the starter solenoid, drained the tank, and replaced the fuel filter. Now it'll crank but she wont start up. There is fuel getting all the way to the injection pump. I'm afraid my problem stems from the pump or the injectors, but I'm unsure of which. Any thoughts? Also, my solenoid or one of my connections to it is sparking right when I first turn the key. I've re-routed my positive cable down to it thinking it was the problem, and no wires that I can tell are touching anything they shouldn't. Is this possibly a ground problem?
Turbo Zach
924
931
50130
#2
You probably will need to bleed the air out of the injector lines. Loosen the lines were they go on the injectors. Turn it over until you have fuel leaking from all lines. Then tighten them up. Older diesels are pretty easy to work on.
Aug 20, 2009
654
117
30
North Vernon IN
#3
I had issues with the Olds diesel that had sat for around 20 years when I first tried starting it throwing sparks and eventually melting the battery wire off. Turned out to be the starter had gotten corroded internally and was shorting out and causing it. Quick rebuild and all was good. As far as not starting its probably air, after it sits for so long the fuel kind of backs out of the lines and or turns into wax in the lines. If you crack loose each injector tube at the injector and give it a few cranks you will usually see fuel spitting out and you can pump the air out that way. Good luck and if you ever want to sell it give me a shout
Carson L W
9
19
#4
So, I did bleed the lines and there still isn't anything happening. Could it be my compression?
Turbo Zach
924
931
50130
#5
What do you mean not happening? No fuel, or will not run? First thing is to make sure your battery is turning the engine over fast enough. Second thing make sure it is getting plenty of fuel to the injectors. If it is smoking out the exhaust but will not run. Then it is getting plenty of fuel, just not ignighting it. Jeck your glow plugs or air heater. Make sure they are working. If it still will not run you need to check compression. Low compression diesels need to turn over fast and have glow plugs to run. Try a little either and see if it will pop on that.
#6
do not.. I repeat do not use ether to start the engine. These engines will not start on ether. Use wd-40. Check the glow plugs unless its 100 degrees outside (lol) she will not start with out the glow plugs. what year is the cutlass? does your wait to start light cycle like it should. Depending on the model on the passenger side fender not far from the battery is a solenoid, if you have this you should hear it cycle during the first turn on of the ignition. Mine is an 1981 with only 85K and I simply love her. 1983 and 1984 they used a computer controlled ecm not just the basics. I will try to help as much as I can
Kratos
48
66
Central Pa
#7
If your glow plugs are anything like the ones used in the 6.2 diesels, they spec out at 3 ohms or less. Most likely about 1.7 ohms is a good one. anything more than 3 ohms, replace
Aug 20, 2009
654
117
30
North Vernon IN
#8
Glow plugs for sure check, mine from sitting most all of them were weak or not working, second make sure the pulses of fuel coming from the injection pump are strong, mine were very weak where the internal seals of the injection pump were ate up from sitting. Rebuilt pumps are available or you could have your existing one rebuilt if you have to
#9
read my post below. maybe we can talk phone?
Carson L W
9
19
#10
So, I checked my glow plugs, they look pretty good. There is fuel coming out my lines but it looks kinda weak. Definitely gonna get a new starter and check the injection pump. I understand these engines often blew head gaskets so if it's not the pump and it's compression then that's what I'll check. I need to find a little time is all, I'm currently going to college, gonna be a machinist. Thanks everybody for the great suggestions. I'll get some pictures up maybe. She's a really clean car.
Similar threads
Classic Truck Consoles Dixie Restoration Depot GBodyParts Mike's Montes P-S-T UMI Performance
