Olds intake exhaust crossover
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,990
Socialist NY
What are you using to block them off?
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
Well, you could have poured a melted piston into them before you did the valve work. But, since you didn't, JB Weld the iron plugs in.
I used Edelbrock heads to get rid of mine.
8,806
7,746
Melville,Saskatchewan
wskirvin
325
423
Indianapolis, In
I used the edelbrock plugs and ground them to a tight fit and jb welded them in place.
Drkuhar
507
896
Girard, IL
Be sure to adhere them some how or it sounds like a wrench in the valley pan rattling around. Took awhile to troubleshoot that one.
TURNA
Jul 24, 2009
10,941
19,990
Socialist NY
may just keep them open and use the valley pan.
Dont want it to not heat up in the winter
Ill see maybe i'll just weld the intake side closed seems easier
