OLDs intake valley pain, I mean pan
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Ok Olds peoples anyone use the FelPro valley pan???
Is this correct for the drivers side exhaust crossover?
The pan does have a double "sealing ridge" FEL-PRO MS96027
So I am assuming this pan fits a bunch of different heads/intake ports
Rktpwrd
Builder of Cool Shjt
4,166
23,915
Calgary, Alberta, Canada
Put it where it belongs IMO:
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
I would have if I sealed the crossover in the heads.
But this car will be a driver.
So I need the crossover or it will take forever to warm up in the winter.
8,818
7,763
Melville,Saskatchewan
I personally like it. Early heads have a smaller crossover than later heads, two different gaskets, you have the right one. Usually a bit sticks out, should be fine.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Sweet thanks
Alerch
285
171
Goose creek SC
I just replaced my valley pan on my big block... the old pan wasnt like that, the new one is the same way as yours.. Fel-pro must have changed the design then some..
L92 OLDS
2,872
3,050
West Michigan
Ditch that POS valley pan! I have assembled several Olds engines using the Mr. Gasket style gaskets shown below. You don't need that goofy pan set up. Leaks, poor fit, etc.
