Olds oil fill tube
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,990
Socialist NY
How do you remove it?
This thing.......
TURNA
Jul 24, 2009
10,941
19,990
Socialist NY
Just pull it out?
JAMCAR223
1,853
5,507
Houston, TX.
Get a block of wood and tap it lightly with a hammer...left, right, left, right. Mine came loose after about 5-6 taps. No damage...
hoffa65
319
416
Atlanta GA
Just pull it out?
yes just a snug pressed fit, depends on rust tho, natures lock tight lol
I have had luck hitting it down with a good bang to break the bond then tap side to side as you pull up on the lower neck
69hurstolds
8,090
17,309
Don't hit it too hard or you will dink it. But yeah, little light love taps back and forth will do the trick.
TURNA
Jul 24, 2009
10,941
19,990
Socialist NY
Thanks!!
69hurstolds
8,090
17,309
Just one more tip....NEVER, and I mean NEVER use the lip of the top of the tube that holds the cap to tap UP on. NEVER. If you didn't hear that, I'll say it again...NEVER!!!!
That piece is just pressed on the top of the tube. Guess what happens when you try to tap up on it? ....a long time ago when I had peach fuzz for a mustache, I learned this the hard way. Don't be that young and dumb me. Come to think of it, don't be that old and dumb me now, either. I don't have a choice, though.
