I'm going to be replacing my sweep cluster with the Rallye Pack and have a few questions. I know I have to re-arrange the wiring in the connector. That part looks pretty straight forward.
1 is a tach filter necessary? I'm using a Jegs SSR distributor with external coil(Same as Pertronix Flame Thrower) Basically has anyone done the swap without a filter and had a smooth operating tach?
2, Does the transmission range indicator from the sweep cluster fit the Rallye cluster?
