Olds ticket to 9s... LS swap adventure.
5,660
12,061
You guys are awesome. Truly. Thank you.
I think I am going to sleep on it. Do some research and maybe try some local LS swap groups first, and make a decision from there.
And you are right, a 4.8 or 5.3 is a much better choice for what I am doing. However as we have seen recently, I don't often make the best decisions. lol
I’m not saying better - I’m saying different. Which is better? Wish I knew. Personally, I like the low dollar factor of the 4.8 and 5.3.
With all of that said, I have a 6k mile 6.0 take out of Mitsu with a broken oil pump spring - FOR FREE. No DOD, but vvt. We were discussing last evening, over a beer or two, filling the block and putting 1k$ set of rods and pistons in it after filling the block and seeing what 40 psi will do.
Ahhh - bench racing - straight up track build though.
4.8L
  • Scared
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,826
So, you don't have 30k floating around to build a big *ss cube Olds in a Rocket Racing block? I guess I can see where changing engines is more fun......or not.
I'd wanna go fast so I'd build another pontiac. 😆
4.8L
Yup, I agree I drank the coolaid, But in my defense I bought the A motor for $400 in 2013.
Turbolq4
1,732
4,207
Nampa Idaho
The 4.8 is the proverbial ace up your sleeve. It has the fat cylinder walls and the best rod angle. It's a big cam and worked heads boost wh*re. I'm of the opinion that they can take the most abuse of all the LS engine family. 5.3 through 6.2 all share the same crank stroke. 4.8 and LS7 are the odd stroke duo, just at opposite ends of the spectrum.
Out of boost is the only possible weak area and they are still plenty strong to push these cars at super legal speeds on atmosphere. Don't be ashamed to clown the dude bro with his flat billed Starter hat and fresh Air Jordans in his mom's Jag.
Reactions: 8 users
Pettrix
25
26
13
You can get the short block billet forged Rocket Racing Olds 455 for around $15k. Billet crank and the bottom end can handle about 2,000 HP+
Top end will cost you another $3k for aluminum heads and intake.
  • Wow
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,826
SD Performance would build a monster 500 inch Pontiac motor for that money. As would Butler. SD is in canuckistan and only a days drive to pick up.
81cutlass
4,639
13,542
Western MN
Dual fuel rails!
I've always wondered why people don't do that more. 36lb or something small on the main side and garden hoses for the high boost stuff.
Reactions: 7 users
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
Guess I have to step my game up sooner than later 😅
