oldsmobile water pump bolt kit
TURNA
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
11,011
Socialist NY
anyone make one?
TURNA
TURNA
Jul 24, 2009
11,011
Socialist NY
Yeah the 403 has none.
I guess when a swap the pump on the 307 I will run to the store and match some up.
Thanks
84dragcutlass
84dragcutlass
909
North Vernon IN
Ive seen some kits on Ebay and a couple other places. Put together by Alloy Boltz i believe
84dragcutlass
84dragcutlass
909
North Vernon IN
Gardner westcott also has some
Reactions: TURNA
joesregalproject
joesregalproject
4,253
Pittsburgh, PA
I take it that ARP doesn't make a kit?
olds307 and 403
olds307 and 403
5,980
Melville,Saskatchewan
olds307 and 403
olds307 and 403
5,980
WUUUUUUUUUUUUUUUUUUUUUUUUUUUT?
You mean the water pump, I assume? The heavy duty cooling applications use a closed impeller water pump. Your 307 from the factory being A/C should have one. The pump I pulled off my 260 was. Anything including a Robert Bosch high flow thermostat to help the 403 is a good idea.
Reactions: fleming442
