OUTER DEW SWEEP INTERCHANGEABLE??????
4oldsmobiles64
35
74
Hello out there. Maybe someone that really knows there stuff can help. I've owned now a 88 Cutlass Supreme Classic, 79 Hurst Olds, Now a 86 442 and a 80 442.
Obviously the outer dew sweep weatherstrip on a 81-88 Cutlass has a curve at the front.
On my 80 442 which again is a 78-80 Cutlass
Is there any other GBODY car - El Camino - Regal - Monte Carlo in the 78-80 years to where the Dew Sweep will work, which is straight without the curve at the front????
I see the 81-87 is easy to find but not for the 78-80 Cutlass.
Thanks for anyones help
69hurstolds
8,195
17,596
According to the GM parts book, 20163354 and 20163355 are the GM part numbers you seek for A47 body style for outer. 20152195 for inner. You would need 2 of the inners. I was to understand Fairchild makes some aftermarket ones.
WanaBa442
555
1,315
New England
I ordered these: window sweeps for my 78 Cutlass.
They don't look like the pic.
Uses screws to install, does not have any chrome beading like the original did.
Fit OK, but not great. But my originals had fallen apart so I needed to fill the gap.
As you said, hard to find these for the early "A" body styles, even harder to find correct ones.
Part listing in the header is for Cutlass, application info lower down states Pontiac GP......
81Regal
1,557
485
83
Terril Iowa
78 to 80 Regal door parts are the only ones that are a direct fit for Cutlass. You could possibly make El Camino or Malibu work by modifying them.
Gonzo1970
898
1,302
Got mine from Rock Auto.. Fairchild. No complaints.
-Gonz
