1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
outer window sweep install
Discussion in 'Buick Regal / T-Type / Grand National / GNX' started by fodoimp, Aug 13, 2009.
Thread Status:
  1. fodoimp
    fodoimp Master Mechanic
    Oct 8, 2006
    370
    Southern New Jersey
    is it possible to replace the outer window sweeps without removing the door glass? just curious looks tricky
  2. Blake442
    Blake442 Geezer
    Apr 24, 2007
    6,680
    619
    Minneapolis
    Yes, you'll have to loosen/remove the lower stops to be able to roll the window down past the window sweep.
    Honestly, the window is only held in with two fasteners, and comes out so easily, either way you do it takes a minimal amount of time.
  3. fodoimp
    Oct 8, 2006
    370
    Southern New Jersey
    thanks alot I knew you would be the one with the answer. I didnt even really look at it yet and didnt realize they were so easy to remove....thought it would be a major headache. was afraid to take it too far apart and everything be out of adjustment. you r the man!
Loading...
Thread Status:
Share This Page
