Part # for efe valve gasket(s) 83 olds 307 y code ???
jim83
Mar 21, 2018
60
23
8
I managed to get an in box nos efe valve - but no gaskets. Please if you know the part # s for the flat 2 hole side & does the "cone" side use a gasket, if so the p/n for that also. Azone, orielly , napa etc dont stock them so can't do an eye match.
Trying to get everything possible before starting the job. Thank You!!!
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
My original exhaust had no gasket between the EFE and the exhaust manifold. If I recall correctly, the EFE has a raised 'cone' in the casting where the flared end of the Y-pipe tube mates.
69hurstolds
8,188
17,570
GM p/n 22526988
OR you can try FelPro 60771
Looks something like this below. Goes between valve and exhaust manifold (flat side of EFE valve). As previously stated, the lower pipe uses the conical side to seal. Sometimes if the cone seal area is a bit pitted, you can always smear some exhaust sealer paste on it before bolting up the exhaust.
EFE valve shown upside down.
  • Informative
  • Useful
