Hi all:
Looking for part number for electrical terminals in the c100 bulkhead for a 1985 el camino with LG4.
I have my original fuse box and a donor bulkhead connector for the power/ignition/choke, etc. However, I need to repin the donor bulkhead and need to order the correct part number for the male terminals. Looks like the electrical terminals come in three ("3") different widths depending on the gauge of the wire. The largest wires (specified as 3.0 mm in the shop manual - somewhere between 8 and 10 gauge wire) look like they are using a standard male 1/4" spade terminal (which I believe is described as a Delphi/Packard 56 series unsealed male terminal. See: http://terminalsupplyco.com/Store/Product.aspx?pc=8917283
The linked terminal has a hook (my original terminals do not have this hook). I fear that these terminals will get stuck and make it difficult to separate the fusebox and bulkhead connector in the future.
Any help on the correct part numbers would be greatly appreciated.
PS I believe that the hook in the male terminal causes this type of tyerminal to be called a "split-tab terminal."
