You 2-door guys don't know how lucky you are. Not only do your inside panels come off easy, you are also spared these vent windows in the rear doors that you don't have. My '83 Malibu has some odd corrosion along the bottom trim (or some kind of glue?), and the bottom pivot stud is snapped on the passenger side. I was happy to find what looked like a good pair on an '84 Cutlass at the local Pick-N-Pull.
So I get them home and notice that the bottom pivot stud is snapped on the passenger side, just like mine:
So I examine the mechanisms to see if I can spot anything different, passenger vs driver side. Passenger side on the left:
Now I suppose I could disassemble, figure out how to re-attach the pivot stud to the window, figure out how to get the thing in without destroying the rubber seal, and then install the spring and nut with less tension like the driver side. Or I could leave it the way it is, so I can remove the passenger vent when I lock myself out of the car (and so any passerby who is crazy enough and figures it out can take the car or anything inside).
So .... my sample is two out of two. I'm wondering how common this is.
