Picking rear gears
CaliWagon83
CaliWagon83
1,829
1,896
Orange County, CA
#13
Well, I’m coming from the context of 26” tires. 29” tires change (lower) the overall RPMs.
olds307 and 403
olds307 and 403
4,060
1,893
Melville,Saskatchewan
#14
airboatgreg
airboatgreg
1,467
1,352
I just did this and I put a 3:70 to pair with my Muncie 4 speed. I drive 60 miles a day to work and back but my car is not a daily driver. I went from a about a 2:80 stock and it made a new car out of it. What do you want? Mileage, performance? You have overdrive so that is a plus. Hard to beat a 370ish gear but with OD you easily can go a 342ish.
Do you drive in a hilly area? Downshifting an issue? or is terrain flat? Gas is relatively cheap now but I expect it to increase so that may be a consideration.
MrSony
MrSony
4,555
2,854
Des Moines, Iowa
#17
At 75mph with my 26.1 tires and 3.42s I'm at 3300rpm, and it's not bad, sound wise, but it's annoying and puts unnecessary stress on an otherwise low strung engine. .67 O/D of a 200r4 would put it at 2200. Much More livable.
29.2" tire, .67 O/D, 4.30 at 75mph calculates out to 2486rpm for this calculator. Always been accurate +/-100 rpm for me.
https://www.crawlpedia.com/rpm_gear_calculator.htm
Texas82GP
Texas82GP
4,648
7,544
Spring, Texas
#19
I calculate 2790 RPM at 85 assuming 0.67 overdrive (please confirm), 29.5" tires, and a 4.30 rear gear. I think that's about right. My daily driver turns 2500 at 80 and 3000 at 95. It's a truck with 4.11 rear and nearly 32" tall tires (275/55/20). It has a 3400 stall and I mush it down the highway at 85+ with no issues.
2.74x4.30=11.72 final drive ratio in first, seems steep but that really tall tire will mitigate it. Looks like a reasonable setup to me.
565bbchevy
565bbchevy
6,019
5,029
Michigan
#20
Similar threads
