Picking rear gears
8,818
7,763
airboatgreg
2,866
3,114
I just did this and I put a 3:70 to pair with my Muncie 4 speed. I drive 60 miles a day to work and back but my car is not a daily driver. I went from a about a 2:80 stock and it made a new car out of it. What do you want? Mileage, performance? You have overdrive so that is a plus. Hard to beat a 370ish gear but with OD you easily can go a 342ish.
Do you drive in a hilly area? Downshifting an issue? or is terrain flat? Gas is relatively cheap now but I expect it to increase so that may be a consideration.
6,824
6,724
At 75mph with my 26.1 tires and 3.42s I'm at 3300rpm, and it's not bad, sound wise, but it's annoying and puts unnecessary stress on an otherwise low strung engine. .67 O/D of a 200r4 would put it at 2200. Much More livable.
29.2" tire, .67 O/D, 4.30 at 75mph calculates out to 2486rpm for this calculator. Always been accurate +/-100 rpm for me.
https://www.crawlpedia.com/rpm_gear_calculator.htm
10,563
14,292
7,986
18,691
I calculate 2790 RPM at 85 assuming 0.67 overdrive (please confirm), 29.5" tires, and a 4.30 rear gear. I think that's about right. My daily driver turns 2500 at 80 and 3000 at 95. It's a truck with 4.11 rear and nearly 32" tall tires (275/55/20). It has a 3400 stall and I mush it down the highway at 85+ with no issues.
2.74x4.30=11.72 final drive ratio in first, seems steep but that really tall tire will mitigate it. Looks like a reasonable setup to me.
9,611
12,666
