Pictures of gbodys with 235/60/15 Tires
YGspider
679
Ontario Canada Eh
I'm buying BF goodrich radial TA tires on my 15" SSII Rallys that i purchesed and i want to see how much better they will be rather then the 14 inch 205/70/14
Oldsmoletick
1,581
10
38
cny
235 60 up front 15x7 camaro
215 65 up front 15x7 olds
*almost the same height tire as the 235, 26 vs 26.1
-83MONTESS-
4,570
967
Bellevue, Ohio
The 235s definatley look alot better than the 225s I have on the front of mine. I regret buying such a small tire for it so I would definatley go with atleast a 235.
Peter
1,175
74
48
MA
axisg
2,685
2,354
YYZ
I run 235/60/15 all around and it fills the wheelwells OK. You could go as far as a 255 or 265 in the rear but keep in mind the taller you make the tire, the harder your motor will have to work to get it up to speed.
Rasheerh
418
69
Cincinnati, oh
this is my cutty
pencero
1,466
25
38
Ind.
w/ that baby v6 you're working w/ you'll probly notice the car feels heavier and more sluggish going up a rim size. I'd wait until power upgrades happen and keep them under wraps if I were you. When you're working w/ a weak v6 like that even the added weight of 1 additional passenger can be significant and you want to remove as much weight as possible for driveability except when the ground iced then the opposite applies bc traction w/o posi = no good take it from me I almost crashed going like 15 mph on a curve of black ice couldn't believe I was losing control at such a slow speed! Maybe toss one of those wheels in the trunk for icey driving although a 50lb bag of sand or salt is better
YGspider
679
Ontario Canada Eh
I dont drive in the snow Gbodys dont deserve that anymore. and a 1" of rim wont make to much of a weigth diffrence.
