Pins on a factory tach
RustBucket
219
60
Houston, TX
Can any of you fellas tell me how i can hook this up outside of the cluster? Trying to wire it temporarily under the hood while i time and tune my engine. Thanks fellas.
L92 OLDS
2,872
3,050
West Michigan
Get a multimeter and check each pin receptical in your instrument panel to see which is 12VDC + and ground, The 3rd pin will be the tachometer signal. Your key will need to be in the run position while checking.
RustBucket
219
60
Houston, TX
Ok so the pin that has the #3 goes to the "tach" on the distributor, correct?
On pin #1 and #2, which is (+) and which is (-)?
Thanks bud.
O. D. Showtime
3,007
3,527
Regina Sask. Canada
Thanks bud.
I think what he meant is that after you find out which two pins are 12vDC and ground...the left over pin (third) would be tach signal.
Not sure if you have the tach bracket for that tach or not...but here is a pic of the connections...
19,990
bracketchev1221
1,386
1,599
Does anyone know where I can find one of those bracket? I would like to add a factory tach to my replace my clock.
