Pontiac 2 + 2 Aero coupe project
flatout
12
46
13
Back working on my Pontiac project. Went to the wrecking yard and found these goodies off of an S10 Blazer. I was told that the S10 Blazer spindles was the way to go if I wanted to upgrade to a C5 Corvette brakes caliber and rotor. Now I'm going to try to install the tall lower ball joints that everyone is talking about but the problem I'm running into is I have no part number. does anyone know a part number. I also decided to try to use the S10 coil springs instead of buying new ones these look perfect and had low miles they are about an inch shorter than the factory ones that I took off my G-Body but they're also a lot thicker wire diameter. what do y'all think, my gold is to lower the front end hopefully about 2 inches .need some help.
Also I'd like to lower the rear end what do you recommend, I can't cut the rear springs do I need to buy some new ones . working on a tight budget that's why I see a bunch of used parts.
ed1948
1,286
1,613
Quinte West, Ontario
Can't help ya..but I do dig the tight budget scene.
84dragcutlass
1,189
1,507
North Vernon IN
Those springs will work, I had a set in my wagon when I swapped in a 6.5 turbo diesel, they will give it a little drop and a firmer ride. All around pretty good in my opinion
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
I have those spring in mine with a big block they will drop your front end right where you want it.
